freakmoped Geschrieben am Juli 21, 2014 Share Geschrieben am Juli 21, 2014 wer hat eine andere hupe verbaut? die originale kommt gar mickrig daher... was findet sich im forum und web: forum topix http://www.tigerhome.de/index.php?showtopic=16338&hl=hupe Tiger Horn 955i & 1050 If any of you find the original Tiger's horn does not do the bike justice,( abit squeaky and japanesey) a nice and quite cheap mod - staying british is to fit a low tone horn from a LandRover Defender!! excellent bass tone and if you need to use it to alert some other road user of your presence it turns heads! the horn is available through most specialist aftermarket landrover parts distributors, down here in Devon we have Brookwell supplies and they retail it as Part No YEB10027 12v Low Tone, it costs £5.35 + Vat and fits both the 955i and Tiger 1050, as my friends 1050 now also boasts a Defender horn.http://www.brookwell.co.uk/ The part is manufactured by Britpart and may be available through othe similar 4X4 suppliers the Britpart number is GI76332 The horn just fits in under the fairing on both model tigers, but you will need to use the brackets supplied with the horn and not the original horn bracket as the holes would have to be drilled out, the trumpet should face backwards slightly to avoid it filling with water! it is still far louder than the original! bild dazu: http://www.biketraveller.org/biketech/mods.html utube: Stebel Nautilus https://www.youtube.com/watch?v=E8gGW5wo9p0&feature=youtu.be https://www.youtube.com/watch?v=6yiaHfPr0ag Stebel Truck Hornhttps://www.youtube.com/watch?v=xpxij-jY1eQ wolo bad boy https://www.youtube.com/watch?v=Aru_ePpOCbc forum dazu: http://www.tigerhome.de/index.php?showtopic=21780&hl=hupe hörproben von eingen http://www.valkmotive.de/online-shop/hupen/alle-hupen/ das OOOGAH Classic Car Fun horn red wär lustig Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Gattino Geschrieben Juli 24, 2014 Share Geschrieben Juli 24, 2014 Hallo ich habe die Doppelhorn Fanfare von Valkmotive ( Twin Set für 39,50 ) unter meiner Verkleidung.. Passt so gerade eben.. aber der Ton ist herrlich... So mancher Autofahrer dreht sich dann immer um und sucht den LKW... und wundern sich, dass es nur ein Motorrad war 1 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben Juli 24, 2014 Autor Share Geschrieben Juli 24, 2014 (bearbeitet) So mancher Autofahrer dreht sich dann immer um und sucht den LKW... und wundern sich, dass es nur ein Motorrad war yess genau das muss es sein das hier nehm ich an hast du? Wolo Very Loud & Black Twin sethttp://www.valkmotive.de/online-shop/hupen/plug-play-hupen/wolo-very-loud-amp-black-twin-set/230-2T anschlüsse der alten hupe verwendet und funzt? oder neue kabel an die batterie gelegt mit sicherung und relais bearbeitet Juli 14, 2015 von freakmoped Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Gattino Geschrieben Juli 24, 2014 Share Geschrieben Juli 24, 2014 Jepp..und genauso isses auch :-D Alte Anschlüsse genommen, verteilt für beide Hupen , ohne Relais = funzt Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben Juli 26, 2014 Autor Share Geschrieben Juli 26, 2014 perfetto. dann werd ich das ding auch mal anprobieren Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben August 25, 2014 Autor Share Geschrieben August 25, 2014 Hallo ich habe die Doppelhorn Fanfare von Valkmotive ( Twin Set für 39,50 ) unter meiner Verkleidung.. Passt so gerade eben.. aber der Ton ist herrlich... So mancher Autofahrer dreht sich dann immer um und sucht den LKW... und wundern sich, dass es nur ein Motorrad war könntest du mir bitte mal fotos machen wie du die untergebracht hast? ich bin gescheitert leider... Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Gattino Geschrieben August 25, 2014 Share Geschrieben August 25, 2014 Hallo, das einzige was ich dir bieten kann, ist folgendes. Ich hab die Hupen an der originalen Verbindung festgemacht. Die 2. hab an einer männlichen Halterung an derselben Schraube festgemacht. Und das sind dann so aus. Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben August 27, 2014 Autor Share Geschrieben August 27, 2014 Die 2. hab an einer männlichen Halterung an derselben Schraube festgemacht. thx4pix! hehe wie definierst du das genau könntest du mir noch eines von oben machen bei eingeschlagenem lenker? da sieht man eh gut dazu Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Gattino Geschrieben August 30, 2014 Share Geschrieben August 30, 2014 Ja Ja.. das kommt davon , wenn man mit einem Tablet versucht zu schreiben.. Es kommt immer was anderes dabei heraus :-P Es sollte "ähnlichen" hießen Egal... wenn ich dazu komme in den nächsten Woche, dann mache ich mal noch ein paar Bildchen dazu Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben September 8, 2014 Autor Share Geschrieben September 8, 2014 danke, eilt eh nicht! Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben Juni 10, 2015 Autor Share Geschrieben Juni 10, 2015 nachdem mich die letzte zeit wieder einige pfeifen übersehen haben (...) vor allem auf der autobahn muss nun das doppelhorn dran hat mir jemand ev ein bild wie die hupen befestigt werden können? thx! bin beim ersten mal ja leider gescheitert Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Technikfan Geschrieben Juni 10, 2015 Share Geschrieben Juni 10, 2015 Moin Freak, da die orginale Tröte nur noch quikte , habe ich die Stebel TM 80/1 (ist nur der Tieftöner aus der Doppeltonhupe) montiert. Klingt sehr überzeugend und man kann die orginale Verkabelung und die orginale EInbauposition verwenden. Die Öffung habe ich nach hinten unten montiert, sodaß kein Wasser hinein kann. Ist m.M. für ein Mopped ausreichend und zum blinde Dosentreiber wecken sehr gut. Schöne Grüße Jens Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
deisterfahrer Geschrieben Juni 10, 2015 Share Geschrieben Juni 10, 2015 Moin, danke für den Thread! Diese nutzlose Originalhupe hat mich jedesmal geärgert, wenn ich sie gebraucht hätte. So was habe ich seit der Schnarre meiner Zündapp nicht mehr erlebt ... Gruß vom Deister Frank 1 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Waldwegsucher Geschrieben Juni 10, 2015 Share Geschrieben Juni 10, 2015 Wäre auch eine überzeugende Alternative : gg Achim 1 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Technikfan Geschrieben Juni 10, 2015 Share Geschrieben Juni 10, 2015 Moin Achim, ein Zughorn wäre auch ganz nett. Es gibt nur kleine Probleme am Tiger... der Einbauraum ist knapp, die Batterie stirbt bei Betätigung des Knopfes und man muß auf passen, daß es einem nicht wie Harry und seiner Laverda geht (Holger Aue).... Schöne Grüße Jens Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben Juli 14, 2015 Autor Share Geschrieben Juli 14, 2015 (bearbeitet) DONE! lösung gefunden wolvo loud twin black set untergebracht, fotos demnäXt testride in die dolomiten am we wird zeigen ob/wies hält bearbeitet Juli 14, 2015 von freakmoped Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
joda Geschrieben Juli 15, 2015 Share Geschrieben Juli 15, 2015 Moin, ich hab die Beschallung eines Krankenwagens (Bosch Tröten) sagen wir "günstig" erworben. Hierbei handelt es sich um die Nachtbeschallung, die etwas gedämpfter ist als die Taghörner. Die Akustik ist ganz passabel Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben Juli 15, 2015 Autor Share Geschrieben Juli 15, 2015 tönt prinzipiell gutaber tw auch nur heiser in niedrigen rpm und bei nur zündung an dh wohl zuwenig strom da wie könnte man das lösen? verkablung passt fix. Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Technikfan Geschrieben Juli 15, 2015 Share Geschrieben Juli 15, 2015 Moin Freak, die neue Tröte hast anscheinend an die orginale Verkabelung gehängt. Da wird das Kabel schön warm... Du mußt dir einen Laststromkreis für die Tröte bauen. Die orginalen Kabel verwenden und statt der Hupe ein Lastrelais dazwischen stöpseln mit den Steueranschlüssen. Dann eine hinreichend dicke Leitung von + der Batterie zu einer fliegenden Sicherung (ca. 20A) und weiter zu deiner neuen Tröte ziehen, von der Tröte zur Lastseite des Relais und wieder zurück zum - der Batterie. Dann kannst du mit der Tröte die Batterie platt machen, aber du brennst die orginalen Kabel nicht ab.... Schöne Grüße Jens Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Emma Geschrieben Juli 16, 2015 Share Geschrieben Juli 16, 2015 Das Zughorn ist doch Megascharf. Gibbet das nicht in einer abgespeckten Version? Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
DonMauzo Geschrieben Juli 16, 2015 Share Geschrieben Juli 16, 2015 ... Du mußt dir einen Laststromkreis für die Tröte bauen. Die orginalen Kabel verwenden und statt der Hupe ein Lastrelais dazwischen stöpseln mit den Steueranschlüssen. Dann eine hinreichend dicke Leitung von + der Batterie zu einer fliegenden Sicherung (ca. 20A) und weiter zu deiner neuen Tröte ziehen, von der Tröte zur Lastseite des Relais und wieder zurück zum - der Batterie.... Hier schön mit Bildchen gezeigt: (klick) Grüße, DonMauzo / Chris Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
freakmoped Geschrieben Juli 17, 2015 Autor Share Geschrieben Juli 17, 2015 Dachte mir dass es ev mehr braucht... Blöde frage. Sollte man kabel warm werden merken? Da Tut sich nämlich nichts. Geht nur im standgas heiser, sonst tiptop. Gruesse aus dem osttirol Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
